NEXTRUDER NOZZLE FLOW COMPARISON
INVESTEGATE
(@investegate)
I compared 3 different nozzles to determine the maximum flow rate in mm3/s. I never thought the values would be so close. Of course, more can be achieved by increasing the temperature.
It would also be interesting to compare this with the Nextruder CHT nozzles. But I'm not a fan of CHT. I think they clog up more easily and are harder to clean.
I will probably only be able to say how the SiC nozzle performs in a long-term damage test in one to two years. However, I already have a Pheatus nozzle made of tungsten carbide on my Prusa MK3, which I have used a lot for the last two years, and it is still good today. And with it I can print at 10 degrees less temperature than with the Nozzle X from E3D.
The Phaetus SiC Nextruder nozzle only costs around 20€. This means that it is not only better in terms of thermal conductivity and wear resistance but also significantly cheaper. You can buy the nozzle here (affiliate link): https://s.click.aliexpress.com/e/_DDh6ZFJ
The filament I used is from Sunlu and is called PLA Meta. It's for speed printing. Normally this is printed at 185-190c. With normal PLA you would need a higher temperature to achieve the same flow rate.
Opublikowany : 15/11/2024 12:58 pm
4 ludzie polubili
INVESTEGATE
(@investegate)
RE: NEXTRUDER NOZZLE FLOW COMPARISON
Opublikowany : 15/11/2024 1:08 pm
3 ludzie polubili
Dlyfer
(@dlyfer)
I love this test! If I had knowed about this before I bought the obxidion nozzle I've would had waited.
Did you also post a youtube video about this? Don't think to many have seen this.
Opublikowany : 22/12/2024 11:49 am
1 ludzie polubili
Tim
 Tim
(@tim-21)
Old post, but wondering if the E3D Brass nozzle was the standard brass or the HF brass version?
Opublikowany : 28/08/2025 2:09 am
