Newb question: Thin internal geometry is being filtered out.
I'm trying out PrusaSlicer for the first time.
I'm having difficulty getting my models to slice correctly.
I often use thin gaps to build internal structures, typically around 0.01-0.05mm wide.
PrusaSlicer is filtering out these structures, and I don't know how to stop it from doing that.
Can anyone offer advice on how to do that, or if it is even possible?
Thanks,
C23
Best Answer by JoanTabb:
you need to be in Normal Mode, or Expert Mode to see this prompt,
IIRC you need a smaller value to display tiny gaps in models
RE: Newb question: Thin internal geometry is being filtered out.
Fabulous, thankyou!
