New firmware 6.4.0 (MK4 and later), pure bliss!
Jean.de.BZ
(@jean-de-bz)
Firmware update? Well, usually, we don't really notice the differences. It's usually the slicer that's where we expect the new features.
However, something has changed here, and for the better: the filament retraction in the extruder. That might not sound very impressive. But in practice, it makes a big difference.
Until now, to remove the filament from the printer, you had to select "Unload Filament." The printer would heat the nozzle to the filament's melting temperature, retract it, and then eject the filament from the top.If you didn't want to load another filament and shut down the printer, you had to go to Control/Temperature/Cooling to start the fan. Then wait for it to cool down before turning off the machine.
(Why remove the filament? To prevent burnt residue from accumulating in the nozzle.)
Now, after filament insertion and purging, the extruder retracts (displayed on the control panel).When you request to unload the filament, with the printer and extruder at room temperature, there's no need for heating. The extruder ejects the filament cold, smoothly, and very quickly. No need to wait to turn it off.
However, if you want to load a different filament, you'll obviously have to wait until it reaches the melting point. Makes sense.
Well, it might not seem like it, but it makes a difference. Because, whoever started unloading and, while it was heating up and expelling filament, did something else. Then forgot...? What was going on? The printer stayed at the melting temperature (230°C for PETG) until it got tired of waiting and sent a "heating off" safety message. Reassuring, but still not ideal.
MK4
Postato : 14/12/2025 2:54 pm
1 persone hanno apprezzato
LarGriff
(@largriff)
Bliss???  Which printer do you have?  6.4.0 on the MK4S is a disaster.  Ever since Prusa merged the 4S, XL, Core One, and Mini into one release we’ve been plagued with unexpected bugs. Whoever came up with that plan should have been fired.  6.2.6 was the last stable, unmerged, release for MK4S.
Questo post è stato modificato 5 months fa da LarGriff
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Postato : 14/12/2025 3:03 pm
NickAtNight
(@nickatnight)
RE: New firmware 6.4.0 (MK4 and later), pure bliss!
That is a most excellent improvement.
That is meant to be my practice, but it is easy to forget that step and end up with a plug !
Posted by: @jean-de-bz
Postato : 14/12/2025 3:38 pm
Posted by: @nickatnight
Yes, leaving filament in a hot end, especially low temp filament like PLA can cause nozzle clogs. Also, it helps with both filament changes and nozzle changes. It's a big improvement.
Postato : 14/12/2025 4:05 pm
Jean.de.BZ
(@jean-de-bz)
I don't know about the MK4S, but for the MK4, this firmware works correctly.
Since the MK4 replaced my MK3S, I've seen continuous improvements thanks to software updates: initially, the MK4 would make a whining noise when it moved down to zero on the print bed. This issue disappeared with the newer firmware versions.
I had never tried printing with Flex or TPU, for fear of clogging the nozzle (bad experiences with PETG on the MK3S, so TPU was out of the question).
I gave it a go with Amazon TPU Basics and the profile integrated into Prusa Slicer. It printed perfectly on the first try, but since it sticks quite a bit, I used blue tape. Flawless. OLYMPUS DIGITAL CAMERA OLYMPUS DIGITAL CAMERA
Posted by: @largriff
MK4
Postato : 14/12/2025 4:54 pm
LarGriff
(@largriff)
I think most of the bugs are related to use of the MMU, so maybe you’ll never see them!  Lucky you!  😁
Postato : 14/12/2025 6:03 pm
Jean.de.BZ
(@jean-de-bz)
There's plenty of fun to be had with color without MMU. 😀
MK4
Postato : 14/12/2025 6:23 pm
sbwalrath
(@sbwalrath)
Utenti
New firmware 6.4.0 (MK4) Causing many issues
I'm having multiple issues with the 6.4.0 on MK4 . Filament loading and unloading. more noises than normal, Print stop 3 times in middle of a build. Tried to load 6.2.4 but I probably have to do a factory reset first because it won't load the earlier version
Postato : 22/12/2025 12:24 pm
Mr Slingman
(@mr-slingman)
Those are awesome prints. I'm trying to do the same thing but my printer (Core One L) doesn't eject the first color. I know I'm missing something, just haven't figured it out yet.
Postato : 28/12/2025 2:11 pm
TavrosLab
(@tavroslab)
I rolled back to firmware 6.2.6 because of poor auto retract performance. On my products made from translucent filament, this feature creates visual and structural defects in the form of air bubbles. There is no way to completely disable it, including micro-retraction when changing filaments. The logic of filament change has changed, the light indication of an approaching change has been removed, and an unnecessary window for confirming the change has been added, which is not always convenient if you need to make a quick change. It is not possible to disable the function of checking for the presence of a plate on the bed. I don't suffer from dementia and I don't need this function.Therefore, I stayed on firmware 6.2.6 and do not plan to change it yet.
Postato : 19/01/2026 10:08 pm
LarGriff
(@largriff)
New firmware 6.5.3 Alpha is out now.  I’m waiting for the “stable” release.
Postato : 12/03/2026 3:00 pm
Mike B
(@mike-b-3)
Small correction - 6.5.3 Beta is out now.  I've done 3 prints with it, 1 of which with PLA supports for PETG part (MMU3 also needs an upgrade to 3.0.4).  No issues.
Postato : 12/03/2026 7:07 pm
