Multi-printer system using a ULINE rack (sharing idea)
I wanted to share this idea for others. If this has been covered before, then my apologies.
We built a 4 printer rack with a Uline cart that accommodates large and small spools. We often use 2kg spools because we print a lot.
For spool holders, I made a few of the spool holders designed by filamentary and found here: https://www.thingiverse.com/thing:2047554
We laser cut cardboard sheets (see middle picture) with slots for the filament. We keep the large spools on top and can feed to either top or bottom printers (see bottom picture).
We are going to build a second rack to accommodate a system with an MMU.
Nice shelf
I like the shelf. I need an enclosure. I wonder if I can design for this type of shelf.
