MMU with Prusa mini?
lutgendorff.film
(@lutgendorff-film)
The title is the question. Could I use the MMU2 with my Prusa Mini? I can see it would need a mounting bracket, but otherwise, is it feasible? Or would I be missing a plug on the board?
Publié : 26/01/2023 1:19 am
If you need to ask the question, then, no.
I'm sure someone somewhere has hacked it but the electronics and software communication is designed to work with the Mk3.
It *is* possible to implement a rudimentary type of colour printing with a Mini and multiple filament changes, see:
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu
Publié : 26/01/2023 2:08 am
Lichtjaeger
(@lichtjaeger)
RE: MMU with Prusa mini?
The MMU1 and MMU2 are incompatible with the Mini.
You could use the Palette.
Publié : 26/01/2023 7:49 am
Jens Hogenbirk
(@jens-hogenbirk)
Membre
I must say, it works for me if you have simple colour changes like text, that you can cut the two colours into separate files and make sure it’s aligned correctly so you can pront one part on the other while its still kind of hot and then you have it.
Publié : 18/07/2025 7:24 pm
