MK4S MMU3 "Parking"
Nodak7
(@nodak7)
MK4S MMU3 "Parking"
I have a MK4s with a MMU3 and in the midst of doing a print job the printer stated it was reloading the filament and then went to parking and hung there. I checked the and there was filament all the way from the MMU to the Extruder. Is there a way to recover from this? I tried a hard reset but all that did was go back to start. Losing my print job. Anyway how is the best way to recover and get the print restarted. BTW my understanding is a "hard reset" is turning the printer off and then back on. Is that correct? I also thought that if you were in the middle of a print that the printer would continue the print. Am I incorrect?
Opublikowany : 23/01/2026 3:53 pm
mnentwig
(@mnentwig)
RE: MK4S MMU3 "Parking"
I wish they would complete the MMU firmware/SW support. I paid full price for a complete product, not a prototype.
Having to reset / power-cycle the printer on common failure modes is completely inacceptable.
Example: Accidentally disable the side filament sensor on Core one (which is not involved in MMU printing), and it results in misleading errors during the next print when loading filament from FINDA to nozzle. It is an old problem, it is understood, nothing happens. But they're designing wooden oak cabinets for this.
Opublikowany : 23/01/2026 4:14 pm
Walter Layher
(@walter-layher)
I agree, this is not a "well-rounded" product. I had bought an MMU2S together with my first MK3S, but kept it in the box. Last year when the upgrades for the MK4S/MMU3 came out, I ordered those upgrades together. Sometimes the combo works just fine, but then suddenly not. Mostly it works if I stand next to the printer and if I go into the next room the probability for problems rises. 🙂
I have it in a Prusa Enclosure and making adjustments to the MMU3 (tension, sensor etc.) is really awkward. I do have the hinged top, but I have my spools on there, so I have to put those to the side first if I want to open the lid.
I have the feeling that every time I use it it puts in some serious effort to remind me how much I do not need it in my life. 🙂
Opublikowany : 23/01/2026 5:15 pm
1 ludzie polubili
LarGriff
(@largriff)
The MK4S/MMU “parking” bug didn’t show up until firmware version 6.4.0.  It bit me a couple of times, but I reverted to 6.2.6 and it has been reliable again.  No word from Prusa, as far as I’ve seen, that they’ve even acknowledged the problem.
The mediocre support for their established MMU product makes me not inclined to throw more money their way for the INDX, which so far is still vaporware.
This post was modified 3 months temu 2 times by LarGriff
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Opublikowany : 24/01/2026 2:11 pm
Nodak7
(@nodak7)
Thanks Lar! I am pretty new to this? How to I "revert" back to version 6.2.6? Am I mistaken about the loss of power during a print job? It just seems that the Printer should have a the ability to get past this problem without having to turn it off (hard reset) and losing your work. I have come across this a number of times now.
Opublikowany : 24/01/2026 8:47 pm
Walter Layher
(@walter-layher)
Posted by: @nodak7
Put the firmware file you want to downgrade to into the topmost directory (root folder) on your USB drive. There should be no other firmware file in this same folder. If there are firmware files in a subdirectory they won't matter to the printer.
Then put the drive into your printer and power cycle it. As soon as you see the Prusa logo double click the push/turn button on the display. It should show a message asking if you want to flash the firmware. Confirm and the firmware will be installed.
Opublikowany : 24/01/2026 10:53 pm
1 ludzie polubili
LarGriff
(@largriff)
Maybe this will get fixed soon with a firmware update.  6.5.3.alpha has been released, but if you have an MMU it seems to also require an update to MMU firmware 3.0.4.  However, the MMU update specifically states it is only to be used with “stable” printer firmware.  I guess I’ll wait for the final release.
Opublikowany : 12/03/2026 2:57 pm
jslevene
(@jslevene)
I just heard back from support about this issue. They said, "We are aware of the problem. The problem should be fixed with FW 6.5.3, if you are waiting for the stable version, meanwhile you can turn off the filament stuck detection."
Opublikowany : 23/03/2026 12:07 pm
