MK4S and MMU3 Troubleshooting slots 4 and 5
kamkars
(@kamkars)
Mitglied
I am trying to calibrate my MMU3 and keep running into the same issue. All 5 slots will preload just fine. When I do the loading test, slots 1-3 work great. However both 4 and 5 have the same issue. The filament will make it all the way to the F Sensor, but doesn't retract back to the MMU3. It just stays in the tube connecting the two. In some cases it will retract some of the way and then stop. I have tried swapping the filament out with ones that has previously worked and the issue still remains. Does anyone have any advice for how I can try and fix this?
P.S. All hardware and software are the most up to date versions. I use mostly PLA from PRUSA filament or Overture.
Veröffentlicht : 14/11/2025 4:19 am
rex555
(@rex555)
RE: MK4S and MMU3 Troubleshooting slots 4 and 5
check the tension screw on the right side of the MMU (if you are facing the printer) it could be too loose. That would be my first thought
Veröffentlicht : 20/11/2025 5:21 am
aero98
(@aero98)
Mitglied
Having issues with MK4S and MMU3 slots four and five, I checked filament path, sensors, and idler tension. Cleaning gears and recalibrating the selector helped, but occasional misfeeds remain. Looking for stable settings or firmware tips to ensure smooth printinghttps://uplandrecord.com /" target="_blank" rel="noopener">.
Veröffentlicht : 02/02/2026 3:34 pm
