Maintenance Time: Replace bearing
I have one printer that I need to replace the bearings after 2 years of use.  It has LM8UU type bearings.  At one time, I replaced them for several months with Drylins, never like them.
What maker of bearing do you suggest?
Posted : 18/10/2020 1:33 pm
RE: Maintenance Time: Replace bearing
Posted by: @charles-h13
I have been working with slide bearings instead of roller bearings for a long time. However, I would recommend oil-soaked sinter bearings rather than drylins. However, you have to print new bearing housings.
sinter bearings like this one: https://caspar-gleitlager.de/produkte/gleitlager/buchsen/50/buchsen-sinterbronze/?option [9]=99&option[10]=103&option[11]=100&number=CA-42565
A significant difference in terms of running smoothness!
Posted : 18/10/2020 3:02 pm
With so many good forum threads on bearings, why create another one?
Posted : 18/10/2020 3:32 pm
jsw
 jsw
(@jsw)
I've been curious as to how long the bearings can reasonably be expected to last.  I think you've probably answered this as 'at least two years' above.  😉
I do periodically use a few drops of machine oil as per TFM, and occasionally a bit of Superlube.
Posted : 18/10/2020 8:18 pm
