Linear advance fail when setting flow rate in tune menu
When adjusting the flow rate to 110% (fillament 1.65mm instead of 1.75) linear advance cause sections of the lines (when slowing down) to disappear (too much adjustment?).
When slicing with 1.1 extrusion multiplier the output is perfect.
Since I normally slice projects at 100% for 1.75mm filament & then adjust for diameter of the filament at print time.
Any one with a suggestion arround having to slice again (this might also have an effect on the "normal" slic3r behaviour as it is normally set to 95% flow rate
Publié : 10/09/2018 9:46 pm
