Is there a way to make a custom "filament_type"?
TJH
 TJH
(@tjh)
Slic3r (1.41.0) has the nifty feature to append some of the details to the file name of the gcode.
But, ... I'd like to add a custom "filament_type". Slic3r calls nylon "PET"--but it's not the same.
I also print with both so it's confusing.
Any way to add to the set of available choices?
Veröffentlicht : 09/09/2018 2:46 am
davidsteinman
(@davidsteinman)
Re: Is there a way to make a custom "filament_type"?
On the Filament Settings tab, select Advanced. You can type directly into the Filament type even though it is a pulldown.
There are a lot of settings you can enter into the filename in Print Settings, Output Options. For example,
[input_filename_base]_[filament_type]_[temperature]F_[layer_height]mm_[fill_density].gcode
There are more, like the name for the filament settings used. I don't think I have seen a complete list anywhere.
David
Veröffentlicht : 09/09/2018 4:55 pm
You can change Filament Settings->Advanced->Filament properties->Filament type to anything you want. From what I can tell, it's purely a convenience setting and doesn't change any actual print characteristics. I created "XT" for Colorfabb XT, and some flex variants. I use this under Print Settings->Output options->Output file->Output filename format as [input_filename_base] [notes] [filament_type] [layer_height]X[nozzle_diameter] [first_layer_temperature]-[temperature] [first_layer_bed_temperature]-[bed_temperature].gcode. In practice, I'm finding the temp and nozzle info more useful. The "type" field is a handy shortcut, but the actual settings matter more when selecting files appropriate to my current hardware configuration.
Veröffentlicht : 09/09/2018 9:41 pm
Mitglied
Thanks. I have been wondering the same thing.
Veröffentlicht : 10/09/2018 12:29 am
TJH
 TJH
(@tjh)
Got it. Thanks for the info. It didn't occur to me to type over the suggested value. I suspect there's some way to modify the list of default choices as well. I understand it doesn't do anything per-se, but it's useful to help keep track when printing the same part in different materials.
Veröffentlicht : 10/09/2018 1:05 pm
I'd like to use that value to identify a safe "no-ooze" temp to use for hotend warmup in my startup gcode, but haven't tried it yet. I think using the same substring matches used in the filament dependencies would work. For now, I use the type value in my file naming to keep things sorted.
Veröffentlicht : 10/09/2018 2:54 pm
