Infill Not Generating on Thin Walls
JaredHuggins
(@jaredhuggins)
Utenti
I've been running into a weird issue with PrusaSlicer 2.7.1 on my MK3S+ running firmware 3.13.2. I'm trying to slice a fairly simple model that has a few thin vertical fins. The problem is that no infill is being generated for those parts, even when I crank the infill density up to 100% just for testing.
Setup:
  • Printer: MK3S+
  • Slicer: PrusaSlicer 2.7.1
  • Filament: Prusament PLA
  • Nozzle: 0.4mm
  • Layer height: 0.2mm
  • Infill: Grid, 100%
  • Wall count: 2 perimeters
  • Slicing profile: Standard 0.2mm PLA profile, minor tweaks to speeds and cooling
What I've tried:
  • Bumped the wall count down to 1 → same issue
  • Changed infill pattern → no difference
  • Enabled Fill Gaps and played with advanced settings like Combine Infill Every → still no infill inside the fins
  • Confirmed model is manifold
  • Looked at the G-code preview layer-by-layer and confirmed nothing is being generated in the center of the fins—only perimeters
I want those thin sections to print solidly, or at least with some kind of fill instead of just empty shells. I know these areas are narrow, but at 0.8mm with a 0.4mm nozzle, I’d expect at least one internal line or an automatic fill.
Is there a slicer trick or setting I’m overlooking, or is this a known limitation/bug in how PrusaSlicer handles narrow geometry?
Postato : 12/04/2025 4:38 pm
Files > Save Project as
Postato : 13/04/2025 6:37 am
