In which material are made the Prusa 3D parts in the MK3S+ printer?
TonyM
(@tonym)
Just regular PLA?
Napsal : 09/06/2021 12:50 am
Knickohr
(@knickohr)
Member Moderator
RE: In which material are made the Prusa 3D parts in the MK3S+ printer?
no, PETG
Napsal : 09/06/2021 7:02 am
All except for the fan shroud which is iirc ABS as it needs a higher temperature resistance.
Napsal : 09/06/2021 8:55 am
Lichtjaeger
(@lichtjaeger)
Official recommendations:
0.2 mm layer height, infill 20% GRID and material PETG.
We recommend using black filament to print all MK3S and MK2.5S extruder parts. If you want different color, you can use it, but the FS-lever part should be definitely dark (black) and the other parts surrounding the IR-Sensor as well. In case you use any lighter colour for the FS-lever it might not trigger the sensor.
Detailed instructions here.
Napsal : 09/06/2021 9:20 am
TonyM
(@tonym)
Thanks guys!
Being new to 3D printing, now I know how PETG feels ...LOL
Napsal : 09/06/2021 4:07 pm
jsw
 jsw
(@jsw)
Posted by: @neophyl
My original fan shroud started to droop after I did a fairly long run of ABS prints.
I printed a remixed version using the PC Blend and it has not drooped since.
Napsal : 09/06/2021 10:25 pm
