Import multiple .STL files from CLI
Christopher Faulkner
(@christopher-faulkner)
Hello
Thank you for taking the time to read this post, it is appreciated.
Hoping someone can point me in the right direction.  I am trying to load multiple .stl files from the command line prompt using 'Slicer' which I believe is identical to 'Prusa' but repackaged for a different printer.
I have a working command line for loading a single .stl as below, but I can't load multiple either with a wildcard or by listing two items in the path:-
"C:\Program Files\Slicer\slicer.exe" "C:\Test\Test.stl" --load "C:\config.ini" - Works perfectly
"C:\Program Files\Slicer\slicer.exe" "C:\Test\*.stl" --load "C:\config.ini" - Does not work
"C:\Program Files\Slicer\slicer.exe" "C:\Test\1.stl C:\Test\2.stl " --load "C:\config.ini" - Does not work
If anyone has any insight on how I can achieve this it would be greatly appreciated 🙂
Many thanks
CJF
Napsal : 04/06/2024 7:40 am
RE: Import multiple .STL files from CLI
All sorted, error in path, works brilliantly!
Napsal : 04/06/2024 9:49 am
JimB
 JimB
(@jimb)
I would try moving all the .stl files to the end of the command line.  So like this
"C:\Program Files\Slicer\slicer.exe" --load "C:\config.ini" "C:\Test\1.stl" "C:\Test\2.stl"
and be sure to quote each stl file separately.  Using *.stl may work, but you probably can't have that inside quotes.
Napsal : 04/06/2024 11:02 am
