I just switched of Cura to Prusa Slicer - Ender 3
Cy
 Cy
(@cy)
My first post. I've just downloaded Prusa Slicer. I've used Cura since I started 3D printing, which was when the Ender 3 was the kid on the on the block.
I was having an issue with Cura on a specific model which was effecting quality and print time, not by much, but enough to bug me. I tried a bunch of things until I said 'Well. what about another slicer?' and obviously it's a little frustrating to start with. The layout is different, I can't find settings I know I've changed in Cura, maybe they're called something different here, I don't know...
I changed the most basic settings in Prusa Slicer, a couple speeds, temperatures, skirt settings, that's about it and OMG! What is mostly a stock profile is better than my best 'tweaked' profile in Cura. Print are taking slightly longer [I'm happy to sacrifice time for quality] but I did also reduce some speeds to match my Cura settings, which is maybe something I'll learn isn't necessary.
By this point Cura is kind of engrained in me and Prusa Slicer seems a little disorientation so I wondered of any Ender 3 users have any nuggets of wisdom or profiles that they'd be happy to share while I get my bearing.
Thanks in advance.
Opublikowany : 11/02/2023 6:06 pm
RandyM9
(@randym9)
RE: I just switched of Cura to Prusa Slicer - Ender 3
You might get more eyes on this post if you moved it or repost in the PrusaSlicer Forum area.
Good luck.
Cheers
Opublikowany : 12/02/2023 5:17 am
1 ludzie polubili
