I have a question !!
vincity.t
(@vincity-t)
Hi
I have got a Prusa I3 Hephestos from BQ for a couple of years now. It works fine.
The belts seem to be good for replacement. What is the exact type of belt I have to order ?
The printer has never been modified. It is just standard.
Thanks for your answer.
Opublikowany : 21/09/2018 9:12 am
Re: I have a question !!
Good morning Vincity.
The Hephestos is a clone of the Original Prusa i3 Idea, and it is not produced by Prusa research, to get an accurate answer you would be better asking on a forum dealing with that model of printer...
However... if we assume that the BQ Hephestos is a close copy of the Original Prusa i3, then the belt will be Gates GT2 6mm wide belts.
I hope this information helps you,
Regards Joan
Opublikowany : 21/09/2018 10:59 am
K7ZPJ
(@k7zpj)
Hi Vincity,
You can find the part info and documentation for your BQ Hephestos printer at this link.
https://reprap.org/wiki/Prusa_i3_Hephestos
Opublikowany : 21/09/2018 10:38 pm
MechLink
(@mechlink)
These are the belts I replaced mine with,
Its been nearly 2 years and I have done over a thousand prints on it and the belts are still going strong.
You will need to get 2x of them if you decide to get them from here
https://www.motionindustries.com/productDetail.jsp?sku=05694842
but that is up to you, just thought I would share
good luck with printing 🙂
See my stuff at
https://www.printables.com/@MechLink
https://www.myminifactory.com/users/MechLink
Opublikowany : 27/09/2018 7:42 am
