how to offset z for thick build plates
Custom Spooled
(@custom-spooled)
I am trying to experiment with different build plates, glass, polypropylene and garolite. I cant get through the auto bed leveling and I know I am just completely missing what I am supposed to due but if I could get some help that would be great. Printing with a MK3S
This topic was modified 6 years temu by Custom Spooled
Opublikowany : 07/11/2019 5:00 am
Crawlerin
(@crawlerin)
RE: how to offset z for thick build plates
P.I.N.D.A. is an induction sensor that reacts to metal. It needs metal within certain distance (IIRC 2 mm) to trigger. Maybe if you put some kind of sheet or foil underneath your new surface?
Opublikowany : 07/11/2019 10:44 am
Custom Spooled
(@custom-spooled)
thank you so much I knew I was missing something stupid. Makes total sense I have managed to use some shim stock during bed leveling to trick the machine. My build plates are 3 and 4mm thickness so the foil under wouldn't work but good idea non the less.
Opublikowany : 08/11/2019 4:13 pm
Posted by: @custom-spooled
Did you apply the foil atop the surface for mesh bed leveling, then remove it for the actual print?
Opublikowany : 08/11/2019 7:07 pm
I have not found the process to different from the original build plate.  Slowly hone it in.
Opublikowany : 08/11/2019 10:52 pm
GertL
(@gertl)
Maybe this guy does what you want.
https://mattshub.com/blog/2017/04/11/printing-on-glass
Gert
Opublikowany : 01/06/2020 2:07 pm
