How to add many of 1 print to queue?
Boysie
(@boysie)
So I have a print in progress or already printed, I want to print many more >20, right now it seems I have to view the printed item in history and add 1,then repeat x times which is silly. Am I missing a trick to add x amt?
Opublikowany : 08/05/2025 8:40 am
AlbertKy
(@albertky)
RE: How to add many of 1 print to queue?
Hello,
select the Item you want to multply, then do a "right click" on that item. A menu opens and the 3rd point is "Set numbet of Instances...". A new Menu opens and you can enter the number of Copies you want.
Or you can select the 4th point at the first Menu and "Fill Bed with Instances"
Hope this Helps..
Greetings, Albert.
Opublikowany : 10/05/2025 12:03 pm
