Horizontal banding issue
jim
 jim
(@jim-2)
I am having an issue with horizontal banding at regular intervals. I thought it may be over extrusion but having calibrated the filament I still have the issue.
Veröffentlicht : 27/08/2021 1:55 pm
Speed, extrusion multiplier, and linear advance
The easiest thing to try is simply slowing the print down. Dial speed back 50% using the front knob mid-print. If that improves things, you know you can fix the problem in slicer settings.
Try changing your z-seam position (Print Settings->Layers and perimeters->Advanced->Seam position). If that improves the appearance, you can try calibrating your extrusion multiplier and linear advance settings for that filament to even out flow.
Veröffentlicht : 27/08/2021 2:24 pm
jim
 jim
(@jim-2)
Banding issue
Thanks for the advise. I tried slowing down the print but it didn't seem to make any difference.
I have calibrated the extrusion multiplier, any suggestions on setting for the linear advance?
Veröffentlicht : 29/08/2021 6:08 am
