High Precision 3D Scanner - I scan for you
I happen to have access to a high precision 3D Scanner similar to this picture.
The scanning error should be ~15µm, I am still learning with this device and I think I can learn the quickest by trying all sorts of different parts to scan.
If you like I can do a scan for you and send you an .stl scan file, however I have some limitations
- scan size should be between 10mm - 200mm
- precision scan should be required and of use
- parts need to be coated in anti reflex spray (I can do that with a spray which desintegrates within a day)
- I have limited time, so I can't do too many scans
- You should handle the shipping fees (I am based in Germany)
Postato : 02/06/2025 7:52 am
1 persone hanno apprezzato
