Help strange pointed oval shapes
Hi recently had a Z axis crash which left the steel runner at an angle to the print plate. Now reset and fixed. When starting a new print the extruder makes odd pointed oval shapes where the brim and scaffolding should be?? This usually results in the print coming off the bed. Tried with many different prints and preloaded ones. Have reset/updated software and run set up again. Any ideas anyone???
Napsal : 10/05/2024 12:01 pm
RE: Help strange pointed oval shapes
I think you should clean the print bed. Make sure the print bed is clean and free from any debris or residue. Use isopropyl alcohol or a recommended cleaning solution to wipe the print bed surface. A clean surface promotes better adhesion, preventing the print from detaching during the printing process.
Napsal : 24/05/2024 4:46 am
