HELP! Knob print for an old Sanyo washer
Sauce
(@sauce)
I've been trying to find replacement knobs for this old Sanyo twin tub washer, but specifically the middle knob cuz it's different from the others. i cant find them anywhere, so I was wondering if anyone has a print of these as a last ditch effort
Opublikowany : 08/02/2026 2:24 pm
This is the sort of small part that really justifies the use of 3D printing and is not too hard to learn to design.
I don't have the washer but that's an interestingly shaped insert - I assume the part looks something like this:
In which case the following OpenSCAD code creates the shape but I don't know any of the measurements - OpenSCAD is a free download so you can measure the part and edit-in the correct values.  The pointer_angle allows you to change the zero point and will probably need to be a multiple of a right angle.
// Sanyo Knob
// Alter these parameters to fit
cloverleaf_leafrad=1.5;
cloverleaf_containingsquare=7;
cloverleaf_innersquare=6;
cloverleaf_depth=10;
locator_x=1.5;
locator_y=2;
inner_cylinder=12;
outer_cylinder_in=16;
outer_cylinder_out=20;
outer_cylinder_height=28;
knob_dia=40;
knob_thickness=20;
taper=5;
pointer_offset=3;
pointer_angle=0;
overall_thickness=30;
// End of alterable parameters
// set curve accuracy - increase to make smoother
$fn=80;
difference(){
    union(){
        hull(){
            cylinder(d1=knob_dia-taper,d2=knob_dia, h=knob_thickness);
            rotate([0,0,pointer_angle]){
                translate([knob_dia/2+pointer_offset,0,0]){
                    cylinder(d=1,h=knob_thickness);
        cylinder(d=inner_cylinder, h=overall_thickness);
        difference(){
            cylinder(d=outer_cylinder_out,h=outer_cylinder_height);
            cylinder(d=outer_cylinder_in,h=outer_cylinder_height);
    translate([0,0,overall_thickness-cloverleaf_depth]){
        cloverleaf();
module cloverleaf(){
  difference(){
        hull(){
            translate([-(cloverleaf_containingsquare/2-cloverleaf_leafrad),-(cloverleaf_containingsquare/2-cloverleaf_leafrad),0]){
                cylinder(r=cloverleaf_leafrad, h=cloverleaf_depth);
              translate([(cloverleaf_containingsquare/2-cloverleaf_leafrad),-(cloverleaf_containingsquare/2-cloverleaf_leafrad),0]){
              translate([-(cloverleaf_containingsquare/2-cloverleaf_leafrad),(cloverleaf_containingsquare/2-cloverleaf_leafrad),0]){
              translate([(cloverleaf_containingsquare/2-cloverleaf_leafrad),(cloverleaf_containingsquare/2-cloverleaf_leafrad),0]){
         translate([-(cloverleaf_innersquare/2+cloverleaf_leafrad),0,0]){
         translate([(cloverleaf_innersquare/2+cloverleaf_leafrad),0,0]){
        translate([0,-(cloverleaf_innersquare/2+cloverleaf_leafrad),0]){
    translate([-locator_x/2,(cloverleaf_innersquare/2),0]){
        cube([locator_x,locator_y,cloverleaf_depth]);
 OpenSCAD purists will note that a minkowski would be more elegant and use fewer lines but hull uses considerably less resources...
Opublikowany : 09/02/2026 10:06 am
1 ludzie polubili
Sauce
(@sauce)
RE: HELP! Knob print for an old Sanyo washer
wow you're a life saver thank you so much for this. I've never 3D printed anything tbh, so i was planning on sending it to someone to 3D print it for me, but i  did measure the knob just now
Opublikowany : 09/02/2026 4:22 pm
You will need more measurements - work through the parameters in the script and replace the placeholder values until you get an acceptable rendering and then send the resulting .stl file to your printing friend - for a precise fit you may need to trial-print, tweak a few decimal places and iterate a couple of times.  All measurements are in mm except the angle in degrees.
Opublikowany : 10/02/2026 6:26 am
1 ludzie polubili
Sauce
(@sauce)
thank you so much for you help!
Opublikowany : 10/02/2026 11:14 am
