Heated bed not turning off after print now
Wobbles
(@wobbles)
all of a sudden the heated bed does not turn off after print ?using prusa slicer and ender 5 .. Not sure what’s happened ?
many help would be appreciated
Ce sujet a été modifié il y a 5 years par Wobbles
Publié : 01/06/2021 8:42 pm
RE: Heated bed not turning off after print now
do you have something like this in your Custom Gcode, End Gcode?
G4 ; wait
M221 S100 ; reset flow
M900 K0 ; reset LA
{if print_settings_id=~/.*(DETAIL @MK3|QUALITY @MK3|@0.25 nozzle MK3).*/}M907 E538 ; reset extruder motor current{endif}
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M107 ; turn off fan
{if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+30, max_print_height)}{endif} ; Move print head up
G1 X0 Y200 F3000 ; home X axis
M84 ; disable motors
Publié : 01/06/2021 11:01 pm
1 personnes ont aimé
VladimirK
(@vladimirk)
Membre
; Filament-specific end gcode
G28 X0 ; home X axis
Search cannot find "M140" at all. Using Duet and RepRap. Sometime it works, sometime not.Calibration_cube_20x20mm
Publié : 23/07/2024 8:10 pm
Glen Hansen
(@glen-hansen)
Membre
If your heated bed doesn't turn off after a print with Prusa Slicer and Ender 5, it could be a G-code issue. Check your end G-code in the slicer settings to ensure it includes the command to turn off the heated bed (usually `M140 S0`). If the G-code is correct, inspect the printer firmware and settings. Reflashing the firmware might help. retro bowl
Ce message a été modifié il y a 2 years 4 fois par Glen Hansen
Publié : 24/07/2024 2:53 am
