Getting cold feet re: Enclosure and MMU3 upgrade
JeffHart
(@jeffhart)
Utenti
I picked up the MK4 Enclosure Bundle earlier this year and then picked up the MMU3 upgrade.  Have not installed either, the installation for  the enclosure looks like it involves disassembling more of the MK4 than I anticipated.  I'm a bit challenged in assembling things, general klutz and easily distracted.
Looking for advise on doing the enclosure or the MMU3 first or attempt a blended build?
Also open to hiring someone in the DC area to assist - I do have a MINI+ that needs adjustment on the Z axis that I'd be willing to barter for an assist.
Or should installing the enclosure and MMU3 be easier than I think it might be?
Postato : 17/09/2024 7:27 pm
Marlene495Hadley
(@marlene495hadley)
Utenti
RE: Getting cold feet re: Enclosure and MMU3 upgrade
Hello!
Start with the MK4 Enclosure since it requires more disassembly, then move on to the MMU3 upgrade. Follow Prusa’s detailed guides for each step. If you’re uncomfortable, consider hiring local help or seeking assistance from maker communities. Take your time and double-check each step to avoid mistakes. Good luck!
Postato : 19/09/2024 11:27 am
1 persone hanno apprezzato
JeffHart
(@jeffhart)
Utenti
Thanks!  Will look for a local maker group
Postato : 23/09/2024 3:32 pm
