Geometry Echos
Hi
i need some Help
What is the problem if i get this Print Geometry Detail Echos to the Print always in Printdirection
The Left Corner is repeded with degreesing bounce
as well as the Fleur repeted up to 5times with drgrecing hight
SOME IDEE Please
SEE Image
Best Answer by Lichtjaeger:
Veröffentlicht : 06/04/2023 2:47 pm
RE: Geometry Echos
Veröffentlicht : 06/04/2023 3:02 pm
RE: Geometry Echos
Thank you sir
I missed the TAG
Goasting so now all is clear on How to act propper
will come back with a Result
Veröffentlicht : 06/04/2023 4:55 pm
RE: Geometry Echos
You can also use the search term 'ringing'
Veröffentlicht : 06/04/2023 5:10 pm
[SOLVED] Geometry Echos,Ghosting,Ringing
and it has been riped off 99% is now of at 65mm/sec thats fine
i did tighten all belts to the limit as the Steppers stall at the end of the printplate (outer Rim)
so im fine with center and 140mm Parts for now
Veröffentlicht : 07/04/2023 5:42 pm
