Gcode Help
Elidari
(@elidari)
Gcode Help
Hi guys I need some help if I try to insert knot into a print and I enter the Gcode code as required i’m lair 25 for instance it’s a six hours printing time how do I know what time I need to come home to insert the knot or do I have to stay there for six hours
Thanks Eli
Elidari
Opublikowany : 01/05/2020 10:49 pm
Dhaya
(@dhaya)
RE: Gcode Help
If you’re using PrusaSlicer then, after adding adding your pause on the layer bar and slicing again, you’ll be able to see an estimated time for every phase of the print on the bottom right of the interface.
Opublikowany : 02/05/2020 11:41 pm
1 ludzie polubili
Elidari
(@elidari)
RE: Gcode Help
Thanks Eli
Elidari
Opublikowany : 03/05/2020 7:35 pm
