Gammamaster RepRap 0.4mm is not a full hardened alloy - it's copper coated with an alloy
_KaszpiR_
(@_kaszpir_)
I just wanted to share a small discovery I had today.
SliceEngineering GammaMaster® Nozzle RepRap 0.4mm apparently is a copper core coated with an alloy which gives it an improved hardness against abrasives and prevents from PETG to stick to it (well it sticks less to it than to the other nozzles :D).
I thought it was full alloy and thus I though it would be more resistant to some forces, similar to the hardened steel nozzles.
Overall I was very pleased how it worked, it printed beautifully for over a year with different filaments (PLA/PETG/ABS/ASA, glow-in-the-dark=abrasive).
Just make sure not to drop it with the orifice straight down to the hard surface such as concrete because it may end as if it ate a lemon 😀
Veröffentlicht : 10/11/2025 10:28 pm
Munawar Shakeel
(@munawar-shakeel)
Mitglied
RE: Gammamaster RepRap 0.4mm is not a full hardened alloy - it's copper coated with an alloy
Thanks for sharing your long-term findings! It's great to hear the GammaMaster holds up so well against abrasives and reduces PETG sticking. Noted on being careful not to drop it
Veröffentlicht : 15/11/2025 11:33 pm
