Four Types of Stone Crushing Machine in Mining industry
crs325578106886
(@crs325578106886)
The production of open-air mines cannot be separated from the stone crushing equipment. The use of a suitable crushing station or high-efficiency semi-portable crusher machine can effectively reduce the size of the ore transportation and improve production efficiency. Open-pit mine surface crushing station is divided into mobile, semi-portable crusher machine, semi-fixed and fixed crusher machine according to the degree of fixation of the crushing equipment and the foundation.
The fixed crusher machine is usually arranged outside the boundary of the stope, or it is arranged inside the stope and combined with the chute. It is not affected by the deepening of the stope and it has a permanently fixed foundation connection with the ground. It will be used permanently after completion and will not be moved. The feeding methods are diversified. They can be unloaded directly by the car, or a buffer silo can be set up for the ore discharge device. The fixed crushing station in HXJQ Machinery is generally located in the crushing workshop of the ore dressing plant and has the same life as mine.
Opublikowany : 21/12/2019 6:45 am
