First 3D Printer (MK4) in High Humidity
blackhole13
(@blackhole13)
Mitglied
Hi everyone,
I just got my first 3D printer, a Prusa MK4 3D Printer, and I’m planning to use it in a room that’s usually around 80% humidity, and (5 - 10 celsius ). My main concern is the electronics—especially the XBuddy board and the PSU—and the risk of condensation causing shorts or corrosion. Unfortunately, I don’t have the option to move the printer to a drier room.
For filament, I’ll be using a dry box with desiccant that feeds directly into the printer via a PTFE tube, so I think that side is covered.
To protect the printer, I’m planning to build a DIY MDF enclosure out of an old wardrobe. I’m on a tight budget, so a large dehumidifier isn’t an option, but I could consider a very small one, 30–50 watts, inside the enclosure if it would actually help.
Has anyone run their MK4 in a humid environment like this?
Would silica gel packs inside the enclosure be enough, or is a tiny dehumidifier worthwhile?
Would it make sense to put silica packs inside the XBuddy board cover to reduce the chance of condensation?
(Please forgive me that i used AI to help me write this topic)
Veröffentlicht : 06/03/2026 5:12 pm
RE: First 3D Printer (MK4) in High Humidity
I have run my mk3s in a garden shed in winter in the UK,
Biggest issue was Mintemp warnings  due to low temperature
A hair dryer could be used to warm the heatbed and nozzle. Before stařting a print. .
I only used pla and petg.
Humidity was ok
Veröffentlicht : 06/03/2026 6:21 pm
blackhole13
(@blackhole13)
Mitglied
Thank you for your reply!
"Running a printer in the UK in a garden shed" this statement kind of gives me hope that i will make it somehow.
I guess UK humidity in that shed was crazy high.
Did you use a drybox with dessicant in it to feed fillament to the printer via PTFE tube, or something simmilar ?
Thank you for your time.
Veröffentlicht : 06/03/2026 6:40 pm
I had mmu3 on the mk3, a d i had 5 rolls of filament on a broom handle supported by two shel ing units... no special humidity control...
Regards Joan
Veröffentlicht : 06/03/2026 7:26 pm
mobile phone corrupting answers....
Veröffentlicht : 06/03/2026 7:28 pm
