Firmware Mk2.5s Rambo card without firmware
samucasam34
(@samucasam34)
Hello friends, would you have a step by step how to upload firmware on Rambo, in time I was buying Prusa parts, part is original, but now I don't know how to upload firmware to mk2.5s help me please, sorry for not having the 100% original because financially I could not acquire, I finished part on eBay, help me how to put the firmware below follows error message I'm trying to put via slicer.avrdude-slic3r -v -p atmega2560 -c wiring -P COM3 -b 115200 -D -U flash:w:0:C:\Users\Samuel Conegunes\Downloads\prusa3d_fw_3_10_0_MK25S\prusa3d_fw_MK25S_3_10_0_4481_RAMBo13a_en-cz.hex:i  avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Jul 16 2021 at 12:28:18                 Copyright (c) 2000-2005 Brian Dean,  http://www.bdmicro.com/                  Copyright (c) 2007-2014 Joerg Wunsch                   Using Port                    : COM3                 Using Programmer              : wiring                 Overriding Baud Rate          : 115200 avrdude-slic3r: stk500v2_getsync(): got response from unknown programmer , assuming STK500                 AVR Part                      : ATmega2560                 Chip Erase delay              : 9000 us                 PAGEL                         : PD7                 BS2                           : PA0                 RESET disposition             : dedicated                 RETRY pulse                   : SCK                 serial program mode           : yes                 parallel program mode         : yes                 Timeout                       : 200                 StabDelay                     : 100                 CmdexeDelay                   : 25                 SyncLoops                     : 32                 ByteDelay                     : 0                 PollIndex                     : 3                 PollValue                     : 0x53                 Memory Detail                 :                                           Block Poll               Page                       Polled                   Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack                   ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- ---------                   eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00                   flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00                   lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00                   hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00                   efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00                   lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00                   calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00                   signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00                  Programmer Type : Wiring                 Description     : Wiring                 Programmer Model: STK500 avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x90 avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x90 avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x91 avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x91 avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x92 avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x92                 Hardware Version: 0                 Firmware Version Master : 0.00 avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x9a avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x9a                 Topcard         : Unknown avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x94 avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x94                 Vtarget         : 0.0 V avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x98 avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x98 avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x95 avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x95 avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x96 avrdude-slic3r: stk500v2_getparm(): failed to get parameter 0x96 avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x97 avrdude-slic3r: stk500v2_getparm(): failed to getparameter 0x97                 SCK period      : 0.5 us                 Varef           : 0.0 V                 Oscillator      : Off  avrdude-slic3r: stk500v2_command(): warning: unknown, code 0x9e  avrdude-slic3r: stk500v2_setparm(): failed to set parameter 0x9e avrdude-slic3r: stk500v2_command(): unknown status 0xc8 avrdude-slic3r: initialization failed, rc=-1                 Double check connections and try again, or use -F to override                 this check.  avrdude-slic3r: stk500v2_command(): unknown status 0x01 avrdude-slic3r: stk500v2_disable(): failed to leave programming mode  avrdude-slic3r done.  Thank you.
Publié : 13/09/2021 2:53 am
