File naming when exporting g.code from Slic3r PE
Hi
I suggest that default name should have materiale in it e.g. screw_PLA_OPTIMAL.gcode
/Martin
Opublikowany : 25/07/2018 11:05 am
Re: File naming when exporting g.code from Slic3r PE
Take a look at Print Settings->Output options->Output file->Output filename format. Try inserting the [filament_type] tag.
Opublikowany : 25/07/2018 4:09 pm
😆 Yeah, sometimes I feel that way...
That's "MISTER Old Fart" to you!
Opublikowany : 26/07/2018 4:50 pm
The current Slic3r 1.41.0-alpha3 already comes with such G-code naming templates.
Opublikowany : 28/07/2018 10:29 pm
