Filament PETG recommendations
clift_d
(@clift_d)
I have mostly been using Prusament PETG Jet Black for my recent printing but I am now reaching the end of my filament stock. I would like to order some more but unfortunately the current situation with orders to the UK <big sigh> means that this isn't likely to be possible for a while.
Can anyone suggest alternative good quality filament that I might be able to get as a substitute in the interim?
Thanks.
Opublikowany : 08/01/2021 2:45 pm
RE: Filament PETG recommendations
Filamentive  (Made in Bradford west yorkshire)  https://www.filamentive.com/
3D prinz        (Made in Telford )            https://3dprintz.co.uk/collections/petg/products/petg-filament-1-75mm-silver
3DQF (Made in Leigh Lancashire) Good for PLA  https://www.3dqf.co.uk/
https://3d-print-works.com/collections/all-3d-print-works-products?ls=en-GB    PLA/ ABS / PVA/ Soluble
 Real PETG is not UK Made, as far as I know, but I have had good experiences with it    (example transparent red)    https://www.amazon.co.uk/Real-Filament-8719128327211-Spool-Transparent/dp/B01MQ1SF9L/ref=sr_1_6?crid=39F7WB2R57KNZ&dchild=1&keywords=real+petg+filament+1.75&qid=1610135269&sprefix=real+petg%2Caps%2C153&sr=8-6
Technology Outlet PETG has also been good and is available next day from Amazon (Example transparent Blue)
https://www.amazon.co.uk/TECHNOLOGYOUTLET-PREMIUM-PRINTER-FILAMENT-PET-G/dp/B06W2PN87J/ref=sr_1_3_sspa?crid=39F7WB2R57KNZ&dchild=1&keywords=real+petg+filament+1.75&qid=1610135269&sprefix=real+petg%2Caps%2C153&sr=8-3-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUE5NzMyMEFXS1Q2UDAmZW5jcnlwdGVkSWQ9QTA2MTgzODIzS0dGVzVFQzFEVjhEJmVuY3J5cHRlZEFkSWQ9QTA5NTMxNDAzMEpGMEpLU1ZNVDlUJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Opublikowany : 08/01/2021 7:51 pm
jsw
 jsw
(@jsw)
I've had good luck with Prusament, Reprapper, Hatchbox and Overture for PETg.
"PETg" is the new PLA."  😉
Opublikowany : 08/01/2021 8:10 pm
Chocki
(@chocki)
Depends on what you are trying to print.
As Joan stated, Technology outlet PETG is good but I found it requires a fairly high temperature, also it is more transparent than a lot of filaments as I think it is actually a T-Glase filament. But prints very strong prints, but can take a bit to get your settings right.
SUNLU PETG, this is actually a really nice PETG blend, and prints at low temperatures closer to PLA than other PETG filaments, I use this one a lot, but it is more flexible than a lot of filaments, the black is nice and opaque if that is important.
I used to use Rigid Ink filaments but they no longer make filament unfortunately.
In most cases drying makes a big difference to print quality especially reducing blobs and stringing. For this I use a food dehydrator.
Opublikowany : 08/01/2021 9:28 pm
clift_d
(@clift_d)
Thanks for the recommendations everyone - I've ordered some Black PETG from 3dPrintz... I'll see how I get on with it.
Opublikowany : 09/01/2021 1:38 pm
