Feed edits
Kev1
 Kev1
(@kev1)
Feed edits
Hi, I'm new here and need a little help, I built a Prusa I3 style 3d printer using 8mm lead screw on all the axis X Y and Z (don't ask) and when using Prusaslicer I have to edit the feed speed every time in Notebook from F5400 to F1600 and F2700 to F1400  and was wondering if there was a way to set this change in Prusaslicer so I don't have to continuously do it in Notebook, thanks😊
Opublikowany : 31/01/2021 1:59 pm
Kev1
 Kev1
(@kev1)
RE: Feed edits
Homemade 3D printer
Opublikowany : 31/01/2021 4:53 pm
RE: Feed edits
In advanced mode, you can set machine settings under Printer Settings->Machine limits,and individual move speeds under Print Settings->Speed. Are your speeds simply too fast, or do you really just need to set different steps per mm in your printer settings so the values you select in PrusaSlicer match your printer's speeds?
Opublikowany : 31/01/2021 10:04 pm
Kev1
 Kev1
(@kev1)
RE: Feed edits
@bobstro
Hi thanks for reply, not sure which I need to do, so how would I set different steps per mms in printer so the values I select in Prusaslicer match my printer speeds, thanks Kev....
Opublikowany : 01/02/2021 5:19 pm
Kev1
 Kev1
(@kev1)
RE: Feed edits
@bobstro
Opublikowany : 02/02/2021 4:24 pm
RE: Feed edits
Do you have to make corrections with other slicers, or only PrusaSlicer?
It sounds like you might benefit from doing the extruder calibration. Matt's Hub has an excellent write-up on the procedure. Basically, you want to verify that your extruder extrudes exactly the amount of filament its told to, and adjust the steps/mm setting until it does.
Opublikowany : 02/02/2021 9:17 pm
Kev1
 Kev1
(@kev1)
RE: Feed edits
@bobstro
Hi, I only use PrusaSlicer and have done extruder calibration, I think because all my axis use 8mms lead screws instead of belts PrusaSlicer feed speeds are too fast ....
This post was modified 5 years temu by Kev1
Opublikowany : 03/02/2021 4:55 pm
