Extrusion feed calculations?
kos.neo
(@kos-neo)
Hello
I want to learn what is the E feed for 100mm travel on X or Y with a 0.4mm nozzle if I want to lay a bead of 0.2mm high and 0.2mm width.
Slicer adjust is feed by all the parameters in config but I need to know because I am trying to write some g code by hand.
Thank you.
Respondido : 09/07/2022 10:07 pm
Kirk Emma
(@kirk-emma)
I have the same question. Now I have a assignment about E feed for 100mm travel.
Esta publicación ha sido modificada el hace 4 years por Kirk Emma
Respondido : 14/07/2022 1:54 am
brucce tran
(@brucce-tran)
Posted by: @kos-neo
Hello
Thank you.
I understand that when traveling 100mm on X or Y with 0.4mm nozzle, it is not easy to place beads with 0.2mm height and 0.2mm width. You need more knowledge to be able to adjust the Slicer as feed by all parameters in the configuration.
Esta publicación ha sido modificada el hace 4 years por brucce tran
Respondido : 19/07/2022 7:02 am
