Extrudr PETG / XPETG too low bed temperature in stock filament profile
MichaelW257
(@michaelw257)
As the titel says, if I use the stock profile for Extrudr's PETG or XPETG with a bed temp of just 70 °C I always get detaching/shrinking issues with my MK3S+ on the textured build plate. Increasing the temp up to 85/90 °C (like the set point for Prusament's PETG) solves my issues.
Maybe the stock profiles could be re-evaluated?
Opublikowany : 27/02/2023 12:19 pm
Load the nearest default profile, tweak it to suit then rename it and save it as a user Preset which joins the list in the dropdown.
Many of us have presets to suit certain filaments or use-cases where the default is not ideal - for example I have some just for white filaments where the rest of the range is fine with the preset but white needs higher temperatures to handle the high pigment load.
Opublikowany : 27/02/2023 12:57 pm
3D_Pfuscher
(@3d_pfuscher)
RE: Extrudr PETG / XPETG too low bed temperature in stock filament profile
Posted by: @michaelw257
I have the same problem. What changes did you end up with? Just the bed temp to 85/90 °C? Any additional tweaks?
Opublikowany : 18/07/2025 9:26 am
