Extruder noise vs nozzle size
rich.elliott
(@rich-elliott)
I believe I’m in a catch 22 situation, or clueless. I love the small nozzle quality. I want to use even smaller nozzles for some detail or ultra detail printing, using a .2, or .1 nozzle. However I don’t see a way to tell the printer from its own menu structure, that I changed the nozzle. Slicer is not even in the mix yet because I’m afraid to calibrate with the extruder noise. The printer wants to extrude at a .4 nozzle ratio and the smaller nozzles can’t pass or  take that pressure, thus the extruder is clicking like crazy. Seems to me when you change the nozzle, this is a device level change and should be reflected in the menu structure. This would be a setting on the printer to define the nozzle installed and set the extruder speed accordingly. I can’t find where to change the feed rate on the printer, so it won’t be over driving the extruder. If I can’t change on the printer, I can’t do a first layer cal.  Aka the catch 22. If I can’t calibrate, then I’m doa.
 Am I missing something here, this seems like a really gross oversight not to associate  a nozzle at the device  level via menu so the feed rates  are adjusted accordingly?
Ce sujet a été modifié il y a 3 years par rich.elliott
Publié : 01/06/2021 2:52 am
RE: Extruder noise vs nozzle size
Good Morning
If you wish to try different nozzle sizes there are a number of parameters that you need to adjust
for a beginner, I would suggest that you start by using the pre programmed nozzle diameters  as offered in Configuration Wizard
Unfortunately neither 0.2mm nor 0.1mm ate on the list
to create your own profile I suggest you start with the 0.25mm profile and work from there
at the very lease, you will need to    change the nozzle diameter
Note some of these parameters are only visible in Advanced or Expert mode
then you need to change the extrusion width to suit your needs
Please be aware that under normal circumstances  the minimum first layer height on a Prusa Printer is 0.2mm, the Maximum layer height, should not exceed 80% of  the nozzle diameter.
80% of a 0.25mm nozzle is 0.2mm
80%of a o.2mm nozzle is 0.16mm
80% of a 0.1mm nozzle is 0.08mm
both of the last two values are smaller than the normal minimum first layer height.
when working with small  nozzles the extruder step size/definition becomes important, you may be better with a geared extruder
I believe One of the other forum users, Bobstro, has a set of personal notes relating to different nozzle sizes, which he makes available on the internet
Please also note that small nozzles block easily, they cannot handle the same range of filaments that larger nozzles can manage, so restrict yourself to plain colours. filled filaments like woodfill, or carbon fibre, will clog your small nozzle immediately.
Publié : 01/06/2021 11:05 am
fuchsr
(@fuchsr)
I think the OP's concern is how to run a first layer calibration after swapping nozzles if the built-in method is geared toward 0.4 mm nozzles.
I'd say that's a good excuse to ditch the stock method in favor of https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-assembly-and-first-prints-troubleshooting/life-adjust-z-my-way/
Just use your slicer to generate a calibration square for the different nozzle settings (use Joan's advice as needed for that) and then just pick whatever square you need after you swapped nozzles.
Publié : 01/06/2021 4:08 pm
Posted by: @rich-elliott
You want a nozzle size small enough to print the smallest details in your prints, but no smaller. Otherwise, you're just adding print time with no appreciable increase in print detail. I find a 0.25mm nozzle is ideal for printing detailed miniatures. I've got a bunch of notes on using different nozzle sizes here that might be useful.
I do a Live-Z (1st layer) adjustment any time I swap nozzles. You're not stuck with the Prusa on-board Live-Z routine. As @fuchsr notes, there are alternative prints that are much easier to use and understand. I've got full notes as well as some test prints for various printers here that you can slice with your chosen filament and nozzle settings.
Prusa is adding new filament types and nozzle sizes to the firmware, but there is a finite amount of space. It's good to know how to slice your own test prints with your chosen nozzle and filament settings and do a good Live-Z calibration. In fact, what I learned on my Prusa has applied to other printers that I own, printing on everything from 100x100 to 300x300 bed sizes printing a wide range of filaments with a 1.2mm nozzle.
Publié : 01/06/2021 5:27 pm
