Experiencing two different versions of Slic3r Prusa Edition
Lars S
(@lars-s)
Hi all,
I'm a bit confused regarding my installment of Slic3r. I alternate between two diffrent versions as seen in the attached pictures. I can't see a pattern in what version starts when. The configuration snapshots also varies with version.
And sometimes it does not work at all. Freezes right after startup.
This has happened before and is solved by de-activate and re-activate and my graphics card ( Radeon RX550 running on WIN10).
Graphics card drivers is up to date.
Anyone seen this problem with two different versions of Slic3r? Could someone point me in the right direction for further troubleshooting?
Regards,
Lars Vegard
Respondido : 11/09/2018 10:22 pm
Phil
 Phil
(@phil-4)
Re: Experiencing two different versions of Slic3r Prusa Edition
After the latest version update, I seem to also have a "Prusa3D Slic3r MK3" and a "Slic3r PE". Not quite sure how that happened. If I run the one that says "Prusa3d" it runs fine. If I try the other one, it has similar issues to what you are describing.
Respondido : 12/09/2018 6:00 pm
