Ender 5 pro auto z bottom when finished
MSTLOL
(@mstlol)
Utenti
Hello folks!
I'm new with prusa slicer software.
I have an Ender 5 Pro printer.When I finish the 3D print, the bed goes to the maximum lower height.
The Ender 5 moves the bed from top to bottom...
For small parts, you have to move the Z-axis manually to finish, and that's chaotic.
In Cura, when finishing the print, doesn't move the Z-axis.
How do I change this parameter in the Prusa?
Best Answer by JoanTabb:
You could delete this line from the "Printer Settings> Custom Gcode>End Gcode"
{if max_layer_z < max_print_height-10}G1 Z{z_offset+max_print_height-10} F600{endif} ; Move print bed close to the bottom
AS you can see, this line is intended to move the print bed down
Postato : 26/03/2024 9:14 pm
RE: Ender 5 pro auto z bottom when finished
Postato : 26/03/2024 9:44 pm
MSTLOL hanno apprezzato
MSTLOL
(@mstlol)
Utenti
Thank you!!!!!!
Perfect!
Postato : 27/03/2024 4:20 pm
