Enable cooling for specific set of layers
Nabil
(@nabil)
I would like to know if there is a way to enable the auto cooling for a specific set of layers.
I do have some filaments that require some amount of cooling for the overhangs mostly. The problem is that if I enable the cooling then some areas will suffer from layer separations or warping.
Thanks for your help.
Napsal : 23/05/2021 12:41 pm
RE: Enable cooling for specific set of layers
Gcode will do this but you will have to tinker a little:
https://reprap.org/wiki/G-code
https://www.simplify3d.com/support/articles/3d-printing-gcode-tutorial/
https://all3dp.com/2/3d-printer-g-code-commands-list-tutorial/
Napsal : 23/05/2021 2:26 pm
Nabil
(@nabil)
@cwbullet
Thanks for the links.
I wish this was possible from the slicer.
Could have been nice to have this feature in PrusaSlicer instead of having to tweak the gcode.
Napsal : 23/05/2021 4:12 pm
Would be a nice feature, why don't you suggest it on GitHub?
Napsal : 23/05/2021 5:28 pm
Nabil
(@nabil)
Don't laugh 😅. I've seen many thread refering to GitHub or people talking about things available on GitHub but I never had a deep look. This is mainly because of the user interface (not intuitive IMO). It's probably time for me to start using that channel.
Thanks.
Napsal : 23/05/2021 7:45 pm
@nabil
Sign up for an account ande submit it to: https://github.com/prusa3d/PrusaSlicer/issues
Napsal : 23/05/2021 8:17 pm
I guess an in between solution is to use the Before layer change Custom G-Code with a conditional :
{if layer_num==xxx}insert_code_for_fan_speed_here{endif}
Napsal : 23/05/2021 9:45 pm
