Does anyone know what PC Blend is blended with?
The only thing I could find is:
Proprietary Formula: Prusa Research compounds the PC with other materials in-house, avoiding styrene found in PC-ABS blends.
After I feed in a bunch of clues such as HDT/Tg and measured shrinkage the AI's "think" it is most likely a PC + polyester blend (PBT, PET etc). Makes sense.
Why do I care? I don't really. Just curious.
Publié : 28/12/2025 8:53 pm
For fun I fed the AI the datasheet PDF and it's convinced it's no longer a polyester blend but:
Prusament PC Blend is a PC-dominant, high-flow, impact-modified polycarbonate using styrene-free modifiers and processing aids — not a PC-polyester structural alloy.
The “other components” are most likely:
  • Styrene-free acrylic or aliphatic elastomer impact modifiers (low %)
  • Flow modifiers / molecular-weight tailoring (branched or copolycarbonate PC)
  • Standard stabilizers (thermal, UV, processing)
This formulation:
  • preserves PC density, hardness, modulus, and moisture resistance
  • increases melt flow to FFF-friendly levels
  • slightly reduces HDT (exactly as observed)
  • delivers very high interlayer adhesion
  • avoids styrene entirely
Publié : 28/12/2025 9:24 pm
