Does anyone here want to guide me to get to my first Prints?
PrusaPrinters profile
(@prusaprinters-profile)
Hi
Sry in the last years my Health not improve but I realy would like print some stuff for me to make the life better Accessible like an special Handle for the Fridge and other stuff. I already assemble my MK3 but I am total confuse what next and how to design something. So if here someone want take your Time to help me to get my first Prints pls tell me. I use an IRC Server who someone I know operate for comuniation. So if you have an IRC Client its easy to add his Server.
Thanks
Postato : 11/08/2023 11:38 am
if you can build a MK3 then you have reasonable dexterity.
Can you draw the part(s) you require?
Can you measure the fitting points for the existing parts and incorporate those into your drawing?
If so - you have done most of the work already ...
it's just a matter of finding software to translate from concept to stl.
Postato : 11/08/2023 1:10 pm
RE: Does anyone here want to guide me to get to my first Prints?
It just took me 1- 2 Years.
Postato : 11/08/2023 3:01 pm
_KaszpiR_
(@_kaszpir_)
Looks like you have not provided your IRC server address?
You can join Prusa discord https://discord.com/invite/4a9uE5yG ( it's like Slack or other chats like iRC but within in browser with image/url preview etc) and ask there ( or even talk on audio/video.
Related to software, I guess tinkercad is the easiest option for making models via web browser, which allows to export .STL files you can load into PrusaSlicer or other software. Also there are really great tutorials on YouTube how to use it.
Postato : 11/08/2023 4:50 pm
like iRC
Are there some IRC who works?
Postato : 11/08/2023 6:43 pm
_KaszpiR_
(@_kaszpir_)
can you explain in more detail what do you mean?
Postato : 11/08/2023 6:48 pm
I use normally only an IRC Server since I can customise everyonething in the client. That not work with some proprietary stuff.
Postato : 11/08/2023 7:45 pm
_KaszpiR_
(@_kaszpir_)
ah, well, ok.
From IRC servers I used to hang out on Libera Chat and Quakenet, but haven't used them for years, mainly because most people migrated to Discord/Slack.
Postato : 11/08/2023 8:28 pm
Hello
(@hello)
Posted by: @prusaprinters-profile
Hi
Thanks
What timezone are you where are you in the world
Postato : 11/08/2023 8:40 pm
OK, reasonable but slow...
I wonder, OpenSCAD is purely text based and can be very potent:
For example, this handle, designed upside down for printability, is produced by the following code:
// Demo fridge handle
// This assumes the handle is held by two screws
screwspacing=80;      // mm - alter to measurement
screwcentretoedge=25; // mm - alter to measurement
screwdiameter=3;      // mm - alter to measurement
screwheaddiameter=6;  // mm - alter to measurement
handlelength=100;     // alter as desired
handlewidth=50;       // alter as desired
handleheight=50;      // alter as desired
handlethickness=10;   // alter as desired
// Calculated from above
mountplateheight=screwspacing+20;
mountplatewidth=screwcentretoedge*2;
$fn=50;  //  Increase if you need smoother curves
translate([mountplatewidth/2,mountplateheight/2,0]){
  hull(){
    cylinder(d=handlewidth,h=handlethickness*1.5);
    translate([handlelength-handlewidth,0]){
difference(){
  hull(){
    translate([0,0,handleheight-handlethickness]){
    cube([mountplatewidth,mountplateheight,handlethickness]);
    translate([mountplatewidth/2,mountplateheight/2,handlethickness]){
      cylinder(d=handlewidth/2,h=1);
  translate([screwcentretoedge,(mountplateheight-screwspacing)/2,0]){
    screwhole();
  translate([screwcentretoedge,mountplateheight-(mountplateheight-screwspacing)/2,0]){
    screwhole();
module screwhole(){
    cylinder(d=screwheaddiameter,h=handleheight-handlethickness/2-(screwheaddiameter-screwdiameter)/2);
  translate([0,0,handleheight-handlethickness/2-(screwheaddiameter-screwdiameter)/2]){
    cylinder(d1=screwheaddiameter,d2=screwdiameter,h=(screwheaddiameter-screwdiameter)/2);
  translate([0,0,handleheight-handlethickness/2]){
    cylinder(d=screwdiameter,h=handlethickness);
Postato : 11/08/2023 10:13 pm
Postato : 14/08/2023 5:09 pm
_KaszpiR_
(@_kaszpir_)
Probably discord invite expired after 7 days.
Maybe mods could provide a new one?
Postato : 14/08/2023 5:19 pm
1 persone hanno apprezzato
misan
(@misan)
Utenti Moderator
I am not sure whether that is a valuable resource or not, but you might want to give it a go: https://www.reddit.com/r/prusa3d/comments/1393czg/anyone_have_the_link_to_the_official_prusa_discord/
Postato : 14/08/2023 8:33 pm
Still get the Error.
Postato : 14/08/2023 10:13 pm
Hello
(@hello)
Not sure what it says but it looks like the button to join try clicking the purple bit
Postato : 15/08/2023 3:12 am
