Discovering limits
Is there a way to find out if the limits set in prusa-slicer are ever encountered? It seems like this would be helpful for tuning. For example, under Print Settings / Speed there is a "Max print speed" and a "Max volumetric speed". It would be nice to know when you bang up against those. It would also be nice to know what type of operation was being affected, e.g. infill, bridge, etc.
Sorry if this doesn't belong here; point me elsewhere?
RE: Discovering limits
After slicing you can switch the preview to speed, to see how close you get to MVP.
Thanks! So... I have "Auto Speed / Max print speed" set to 20mm/s, but I see all sorts of speeds above that. Does that mean Auto Speed only applies to print speeds which are set to zero?
Never mind, the max speed obviously applies only to speeds set to zero because it's under Auto Speed. Duh.
