Difference between MK3S and MK3S+
Jon_G
(@jon_g)
I’ve been away from the forum for a while.  What is the difference between these 2models?
What does the + add?
Thanks,  Jon
Napsal : 26/07/2021 12:13 am
Is it worth it? I have not upgraded!
the + adds a new Supa Pinda, and a revised filament sensor plus clamps for the Y rails and Y berings, on to p of some easier to assemble modifications.
If your Mk2S is running well, you will not see a huge differnce upgrading to the +
Napsal : 26/07/2021 2:32 am
MK3S+
I have to agree.  I have replaced my Pindas slowly with Superpindas on most of the printers during routine maintenance, I have had only nominal improvement.  One the mini, they have made a huge difference, but the Mk3S, it has been a small change.
Napsal : 26/07/2021 2:55 am
tg73
 tg73
(@tg73)
Bearing clamps
In the past I've always noticed slight slack/wobble in the Y-axis. Maybe this was because I used Misumi bearings, but I think the U-bolts were generally not a great way to hold linear bearings. With the new bearing clamps, I can finally adjust the amount of compression evenly on the bearings to get the fit just right - smooth movement, zero slack/wobble.
There was also a revision to the extruder printed parts to improve airflow over the V6 heatsink. I'm not sure if this was part of the + update, or just a prior revision. You might find this useful if you suffer from heat creep, which for example can be one cause of bad tips with MMU.
Napsal : 26/07/2021 5:36 pm
Bearings
I don’t think it is the Misumi Bearings.  I have them and they work fine.
Napsal : 26/07/2021 7:08 pm
Praveen Justus
(@praveen-justus)
Firmware compatibility
Someone can help me on this is very helpful for me, I have couple of MK3/S/S+ printers and having some issues on the printers while printing.  which firmware versions are most is compatible for each models  and I can use any slicer version to flash firmware process...?
Napsal : 16/02/2024 9:51 am
RE: Difference between MK3S and MK3S+
this link identifies the latest firmware for each printer variant
https://help.prusa3d.com/downloads
you can use Prusa Slicer to flash the firmware the latest version is probably best, that can also be downloaded from the link above
Napsal : 16/02/2024 11:46 am
