Destroying Prusa
eng.shaimaa.elsersy
(@eng-shaimaa-elsersy)
Destroying Prusa
My Prusa didn't work since March last year because of the damaged hotend then I bought a new one then the problem was with the plastic collet then I bought a new one then now the filament was pulled successfully then it was blocked in the nozzle.
Consquently it prints vibrated lines.
What is the reason ? What can I do ?
Thanks,
Veröffentlicht : 03/03/2022 12:42 pm
Marvin
(@marvin-5)
RE: Destroying Prusa
Hey,
the blocked nozzle sounds either like a too low temperature or maybe a missalignment of the nozzle, wich could happen when replacing the hotend.
Please check if the nozzle sits straight in the extruder and, if possible, post a pic of it. Also let us please know what kind of filament you are using and the set hotend temperature.
The vibrated lines are very likely an too loose drive belt or a dry or broken linear bearing. Please check those by using the manual.
btw, wich printer do you use?
Veröffentlicht : 03/03/2022 8:35 pm
eng.shaimaa.elsersy
Thanks A lot , I will try it.
Veröffentlicht : 05/03/2022 9:15 am
Please show us a picture of the vibrated lines.
Veröffentlicht : 05/03/2022 5:36 pm
