Cut tool suggestion
Apologies if this isn't the right place, I couldn't see anywhere for feedback and suggestions.
I would like the "Cut..." tool in Sl1c3r PE to have the option to autogenerate alignment peg holes in the cut faces, with a separate option to print the pegs, probably always upright with a brim.
D-shaped pegs seem to work best as they give orientation as well as alignment. Sl1c3r PE knows enough about the object to generate long-enough pegs and also to decide how many are required, plus how big they can be made without risking the perimeters of the cut faces.
Re: Cut tool suggestion
Ciuld raise this as a request on the Prusa git hub page?
Joan
