Core One, using the texture sheet and no way to change Z axis
doug dunker
(@doug-dunker)
I bought a texture sheet and I need to change the Z axis and I can not find a way to do so.
Some suggestions for older models use the Live Adjust  Z, but there's no configuration in the Core One settings that I can see.
Posted : 05/11/2025 12:00 am
RE: Core One, using the texture sheet and no way to change Z axis
Z calibration should be automatic on the Core 1
the core 1 uses astrain gauge in the extruder to sense the build plate surface on every print start
Posted : 05/11/2025 1:35 am
_KaszpiR_
(@_kaszpir_)
You can adjust z offset in the PrusaSlicer, some people were reporting similar issues with MK4S so you may find answers in different forums section.
Posted : 05/11/2025 7:50 am
doug dunker
(@doug-dunker)
KaszpiR
Can you guide me on the location of the setting and what I need to start the settings with?
Thanks
Posted : 05/11/2025 11:40 am
doug dunker
(@doug-dunker)
I found the location of the Z offset in the Printers setting / General / Z offset. I made it -0.2mm.
this fixed the issue. Thanks
Posted : 06/11/2025 2:36 am
