Copy friend’s configuration of Prusa to my Maker select Plus
MrChips
(@mrchips)
My first post, Prusa sounds like a terrific software with lots of user configuration possibilities.
My friend is running the latest version of Prusa on his Maker Select Plus, I have the same printer.   I have downloaded the same version of Prusa.   I’m a new user and would like to know is he can send me his configuration?
Respondido : 03/12/2022 12:33 pm
RE: Copy friend’s configuration of Prusa to my Maker select Plus
There are a couple of ways.
He can export a configuration bundle from his setup. That will save every non system standard print, filament and printer on his system into a bundle.  Then you can use the import config bundle option to load it onto my other system you want and get them all. This method is the best for also making backups.
The limitation on this method is that it stores all the non standard ones. If you just want a subset then the easiest is to just save a normal project,  that has a single print, filament and printer saved as part of it. Just use a basic cube or something. Then when you open the project on a different machine you can manually use the save option next to the profile you want to save. So if you want to save the printer only then just save that one.
The bundle is the easiest option though.
Respondido : 03/12/2022 1:10 pm
MrChips
(@mrchips)
Thanks, this will make copying his configuration much easier and accurate.
Respondido : 03/12/2022 2:11 pm
