Context Idea: MINDA / PINDA probe
I have an idea for a contest.  Recycle that old MINDA or PINDA Probe.  What ideas do you have for use of that old probe?
Opublikowany : 25/11/2020 12:29 pm
1 ludzie polubili
ChillyPenguin
(@chillypenguin)
RE: Context Idea: MINDA / PINDA probe
I was hoping to recycle mine into a filament sensor, FINDA style:
Opublikowany : 25/11/2020 6:06 pm
Title should be Contest Idea.
Opublikowany : 25/11/2020 6:35 pm
@chillypenguin
Do you have a wiring diagram and STLs for that?
Opublikowany : 25/11/2020 6:36 pm
I see that is from MMU2 assembly:
https://help.prusa3d.com/en/article/finda-setup-and-troubleshooting_2250/
Opublikowany : 26/11/2020 4:23 pm
Does anyone think this could be used as a raspberry pi filament sensor?
Opublikowany : 26/11/2020 4:24 pm
ChillyPenguin
(@chillypenguin)
I don't see why not. Does Octoprint support filament sensors connected via GPIO?
Opublikowany : 26/11/2020 6:35 pm
Cynan
(@cynan)
Maybe Prusa could sell the MMU2S without FINDA for a small discount and let you use the old PINDA that way?
Opublikowany : 28/11/2020 8:14 pm
Hmm there are a couple octoprint plugins: https://plugins.octoprint.org/plugins/smartfilamentsensor/
Opublikowany : 28/11/2020 8:34 pm
With_Maltodextrin
(@with_maltodextrin)
As I put the just-removed MINDA into the SuperPINDA's baggie I had this thought too, good idea.
I haven't looked at it at all, does the MINDA return a simple open/closed signal, or an analog value (which then has some threshold to act like a switch) as the sensed object gets closer?
Opublikowany : 02/12/2020 10:41 pm
