Compare PrusaSlicer with Ideamaker
Thought it might be interesting to compare these two slicers. I have working profiles for PS and have located some for ideamaker. The instructions that come with the Ideamaker profiles say "Once Downloaded: use the Import->Import from local disk option on the ‘Select Template’ option found under start slicing." Which makes no sense to me. The only start slicing option I can find is greyed out (presumably untill you give it something to slice).
BTW I found these profiles here , they are .bin files.
RE: Compare PrusaSlicer with Ideamaker
Last I knew, there was no Prusa I3 series profile for Ideamaker, and I did not see one obvious at the link you gave. Is one available for the Prusa?
I'm not using a Prusa printer, that's why I posted in General discussion. Not interesting for me but I believe there are Mk3s and Mini profiles available in the Library.
