Communication error There was a communication error while Error: Printer keeps requesting line 6446 again and again, communication stuck
ODT55
(@odt55)
tried everything -- same irror
Changing monitoring state from "Connecting" to "Operational"
Send: N0 M110 N0*125
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin Creality 3D SOURCE_CODE_URL: https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:CR-10 V2BLTouch EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:EEPROM:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:1
Recv: Cap:Z_PROBE:1
Recv: Cap:LEVELING_DATA:1
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: ok
Send: M21
Recv: echo:TF init fail
Recv: ok
Recv: Error:checksum mismatch, Last Line: 6445
Recv: Resend: 6446
Recv: ok
Send: N6446 G1 X5 Y{print_bed_max[1]*0.85} F{travel_speed*60}*46
Recv: Resend: 6446
Recv: ok
Recv: Resend: 6446
Recv: ok
Recv: Resend: 6446
Recv: ok
Recv: Resend: 6446
Recv: ok
Recv: Resend: 6446
Changing monitoring state from "Finishing" to "Error"
Send: M112
Send: N6448 M112*31
Send: N6449 M104 T0 S0*30
Send: N6450 M140 S0*82
Changing monitoring state from "Error" to "Offline after error"
Connection closed, closing down monitor
Closing down send loop
Opublikowany : 27/10/2023 2:05 am
ODT55
(@odt55)
RE: Communication error There was a communication error while Error: Printer keeps requesting line 6446 again and again, communication stuck
Stuck irrespectibve of model loaded
Opublikowany : 27/10/2023 2:06 am
ODT55
(@odt55)
Recv: ok
Send: N1 M115*39
Recv: Cap:EEPROM:1
Recv: Cap:Z_PROBE:1
Recv: ok
Send: M21
Recv: ok
Recv: Resend: 6446
Recv: ok
Recv: Resend: 6446
Recv: ok
Recv: Resend: 6446
Recv: ok
Recv: Resend: 6446
Recv: ok
Recv: Resend: 6446
Recv: ok
Recv: Resend: 6446
Send: M112
Send: N6448 M112*31
3Delight
(@3delight)
Moderator Moderator
Those logs show you as using a Creality printer... This is a forum for Original Prusa Research printers only.
Opublikowany : 27/10/2023 2:35 pm
