Cloth for IPA
gglockner
(@gglockner)
Cloth for IPA
I have been using disposable paper towel when I clean the print bed with 91% IPA. The paper towel creates some waste. What about replacing the paper towel with a synthetic chamois cloth, which can be washed along with laundry?
Publié : 20/04/2021 6:35 pm
jsw
 jsw
(@jsw)
RE: Cloth for IPA
Paper towels are one luxury I do not wish to give up.  I throw them into the recycle container and I assume they end up as something like that sandpaper toilet paper that you get in public restrooms.
Publié : 20/04/2021 6:57 pm
RE: Cloth for IPA
Blue shop towels leave behind less lint. The problem with any sort of reusable material is that grease will build up over time, and you can end up transferring some back onto the print surface. Unfortunately, 3D printing is not a very "green" hobby. There tends to be a fair amount of waste.
Publié : 20/04/2021 7:52 pm
tentaclejoe
(@tentaclejoe)
Membre
RE: Cloth for IPA
I usually use half a paper towel to clean the bed and once done I use that piece to clean the table my printer is on. Then I place it into a plastic bag (unless it's soiled) that is pinned to the table and use the scraps for cleaning tools and whatever else needs a wipe before I throw them away.
Publié : 20/04/2021 8:21 pm
RE: Cloth for IPA
People often use conditioner in washing machines,
Conditioner can be a release agent for 3D printing...
I would steer clear of fabric for cleaning the build plate.
regards Joan.
Publié : 20/04/2021 10:52 pm
muddymaker
(@muddymaker)
RE: Cloth for IPA
I've been using a microfibre lint free cloth for years now without any problems. You save money on paper towels and you help out the environment a little. The one you see pictured has been through the wash no less than probably a dozen times and it cleans the build surface better than paper towels in my opinion. I also use 100% IPA, so your experience may vary.
Publié : 21/04/2021 12:35 am
muddymaker
(@muddymaker)
RE: Cloth for IPA
I should also mention that I never handle any of my build sheets with my bare hands. Gloves are your best friend 👍
Publié : 21/04/2021 12:54 am
1 personnes ont aimé
Membre
RE: Cloth for IPA
I use Viva low lint paper towels or the blue ones from Lowes.
Publié : 21/04/2021 1:45 am
Clarmrrsn
(@clarmrrsn)
RE: Cloth for IPA
For those of us in the UK, or with access to an Aldi I use these to clean the bed.
https://groceries.aldi.co.uk/en-GB/p-power-force-dishcloth-trad-traditional-126g-5pack/25372366
They are .59p for a pack of 5, I tried their microfibre version but they are coloured and IPA leaves nice yellow, green and blue die on the PEI sheet.  So word to the wise, avoid the microfibre ones from said store.
These work very well.
Tank you very much!
Publié : 21/04/2021 7:07 am
StanHD
(@stanhd)
RE: Cloth for IPA
Posted by: @clarmrrsn
Thanks, will give those a try.
I am using the new Satin sheet (really like it) which provides good adhesion with the "dish soap" and water, but needs doing every 2-3 prints. If you wipe it with 100% IPA and a standard paper towel, the residue caused by the slight abrasive surface seems to have a negative affect on the adhesion. It would be nice to be able to wipe with IPA when printing "quick" changes, then utilise the "wash & dry" process less often. (Yes I know, I'm lazy !)
Publié : 21/04/2021 8:53 am
Membre
RE: Cloth for IPA
@clarmrrsn
I will have to check Aldi in the US.
Publié : 21/04/2021 9:54 am
